Run a Hubot bot
Quick start guide
The fastest way to start with Hubot bot is to use Hubot boilerplate. The boilerplate is a simple Node.js package that requires Hubot and the Rocket.Chat adapter. The bot can then be executed using a bin file in production, or via the package scripts locally using npm run local or yarn local.
Navigate to the folder where you want to work with the bot and proceed with the following steps:
1. clone the boilerplate repo and install dependencies
git clone https://github.com/RocketChat/hubot-rocketchat-boilerplate
cd hubot-rocketchat-boilerplate
npm install
2. create a .env file with the following content
export ROCKETCHAT_URL=myserver.com
export ROCKETCHAT_USER=mybotuser
export ROCKETCHAT_PASSWORD=mypassword
export ROCKETCHAT_ROOM=general
export ROCKETCHAT_USESSL=true
Adjust the content to fit your server and user credentials. Make sure mybotuser has a BOT role on the server. For more information on how to create a bot user please refer to this page.
3. run the bot
source .env
bin/hubot
After executing the last command, hubot will try to connect to the Rocket.Chat instance and then will listen to messages in general room:
bin/hubot
audited 390 packages in 1.929s
found 1 low severity vulnerability
run `npm audit fix` to fix them, or `npm audit` for details
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [startup] Rocket.Chat adapter in use
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [startup] Respond to name: Hubot
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [startup] Respond to alias: mybotuser
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [connect] Connecting { username: 'mybotuser',
password: 'mypassword',
ldap: false,
host: 'myserver.com',
useSsl: true,
timeout: 20000,
rooms: [ 'general' ],
allPublic: false,
dm: true,
livechat: false,
edited: false,
integrationId: 'js.SDK',
roomCacheMaxSize: 10,
roomCacheMaxAge: 300000,
dmCacheMaxSize: 10,
dmCacheMaxAge: 100000 }
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [connect] Connected
[Fri Sep 27 2019 23:24:19 GMT+0300 (Eastern European Summer Time)] INFO [login] Logging in mybotuser
[Fri Sep 27 2019 23:24:20 GMT+0300 (Eastern European Summer Time)] INFO [subscribe] Preparing subscription: stream-room-messages: __my_messages__
[Fri Sep 27 2019 23:24:20 GMT+0300 (Eastern European Summer Time)] INFO [subscribe] Stream ready: 2
[Fri Sep 27 2019 23:24:20 GMT+0300 (Eastern European Summer Time)] INFO [reactive] Listening for change events in collection stream-room-messages
[Fri Sep 27 2019 23:24:20 GMT+0300 (Eastern European Summer Time)] INFO [joinRoom] Calling (async): ["GENERAL"]
4. talk to your bot
On the server, login as a regular user (not the BOT user), go to general room, and try the following commands:
mybotuser what time is it
Bot's response to what time is it
This message will also appear in the terminal window:
[Fri Sep 27 2019 23:32:06 GMT+0300 (Eastern European Summer Time)] INFO [received] Message in room GENERAL
[Fri Sep 27 2019 23:32:06 GMT+0300 (Eastern European Summer Time)] INFO [received] Message n6eQ5H7ctRiGuzMRp from docsUser
[Fri Sep 27 2019 23:32:06 GMT+0300 (Eastern European Summer Time)] INFO Filters passed, will receive message
[Fri Sep 27 2019 23:32:06 GMT+0300 (Eastern European Summer Time)] INFO [sendMessage] Calling (async): [{"msg":"@docsUser It's 23:32 and 6 seconds","bot":{"i":"js.SDK"},"rid":"GENERAL"}]
Another command:
mybotuser rc version
Bot's response to rc-version
[Fri Sep 27 2019 23:40:20 GMT+0300 (Eastern European Summer Time)] INFO [received] Message in room GENERAL
i Sep 27 2019 23:40:20 GMT+0300 (Eastern European Summer Time)] INFO [received] Message AvnvCca3Do8PPfRCB from docsUser
[Fri Sep 27 2019 23:40:20 GMT+0300 (Eastern European Summer Time)] INFO Filters passed, will receive message
[Fri Sep 27 2019 23:40:21 GMT+0300 (Eastern European Summer Time)] INFO [sendMessage] Calling (async): [{"msg":"You're on Rocket.Chat 1.2.0-rc.0, using Hubot 3.3.2.","bot":{"i":"js.SDK"},"rid":"GENERAL"}]
[Fri Sep 27 2019 23:40:21 GMT+0300 (Eastern European Summer Time)] INFO [sendMessage] Calling (async): [{"msg":"Adapter version 2.0.0-development, using version 0.2.9 of the SDK.","bot":{"i":"js.SDK"},"rid":"GENERAL"}]
[Fri Sep 27 2019 23:40:21 GMT+0300 (Eastern European Summer Time)] INFO [received] Message in room GENERAL
Run a Hubot bot on production
With the example above, you can run the bot in production using the following command:
bin/hubot -a rocketchat
This command will install dependencies and run the bot with Rocket.Chat's Hubot adapter.
Advanced instructions
Configuration
When running locally, dotenv is used to load configurations from the ./.env file. That makes it easier to set environment variables.
Please a full list of environmental variables here.
Please pay attention that if ROCKETCHAT_URL is using https://, you MUST setup websocket pass-through on your reverse proxy (for example, NGINX) with a valid certificate (not self-signed). Directly accessing Rocket.Chat without a reverse proxy via https:// is not possible.
Running in production
There are executables for different environments that all run the Hubot binary:
  • bin/hubot - for Linux/Unix
  • bin/hubot.cmd - for Windows
  • Procfile - for Heroku
Before running, make sure your production environment has the required environment variables for the adapter, url, user, name and pass. As an alternative, you can add them as command-line parameters, like -a rocketchat.
Environmental variables should be populated on the server before the launch (see configuration). The launcher will also install npm dependencies on every run, in case it is booting in a fresh container (this isn't required when working locally).
See more information on deployment configurations here.
Adding scripts
Scripts can be added to the ./scripts folder, or by installing node packages and listing their names in the external-scripts.json array. There is an example of each in this repo but neither is required.
Checking example scripts
The boilerplate comes pre-packed with two scripts as demos for manual tests. In each of the following script, you can talk to a bot in a public channel by prefixing the bot's username or in direct messages without the bot's username.
  • what time is it or what's the time - Tells you the current time
  • rc version - Gives you version info about Rocket.Chat and Hubot (two messages)
Deployment using Docker
1. clone the hubot repo and go into the clonned directory
git clone git@github.com:RocketChat/hubot-rocketchat.git
cd hubot-rocketchat
2. start the Docker container
docker run -it -e ROCKETCHAT_URL=your rocketchat instance>:<port> \
-e ROCKETCHAT_ROOM='' \
-e LISTEN_ON_ALL_PUBLIC=true \
-e RESPOND_TO_DM=true \
-e ROCKETCHAT_USER=mybotuser \
-e ROCKETCHAT_PASSWORD=mybotpassword \
-e HUBOT_NAME=bot \
-e EXTERNAL_SCRIPTS=hubot-help,hubot-diagnostics \
rocketchat/hubot-rocketchat
On the container launch, hubot will try to connect to the Rocket.Chat instance and then will listen to messages in all public rooms:
[Sun Sep 29 2019 16:49:54 GMT+0000 (UTC)] INFO Starting Rocketchat adapter version 1.0.11...
[Sun Sep 29 2019 16:49:54 GMT+0000 (UTC)] INFO Once connected to rooms I will respond to the name: rocketbot
[Sun Sep 29 2019 16:49:54 GMT+0000 (UTC)] INFO I will also respond to my Rocket.Chat username as an alias: mybotuser
[Sun Sep 29 2019 16:49:54 GMT+0000 (UTC)] WARNING No services ROCKETCHAT_ROOM provided to Hubot, using
[Sun Sep 29 2019 16:49:54 GMT+0000 (UTC)] INFO Connecting To: <rocketchat_instance>
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Successfully connected!
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Logging In
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Successfully Logged In
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO rid: []
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO All rooms joined.
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Preparing Meteor Subscriptions..
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Subscribing to Room: __my_messages__
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Successfully subscribed to messages
[Sun Sep 29 2019 16:49:55 GMT+0000 (UTC)] INFO Setting up reactive message list...
3. talk to your bot
On the server, login as a regular user (not the BOT user), go to general or any other room, and try the following command:
mybotuser time
You can also talk to the bot using its alias:
rocketbot time
Both commands result in the same output:
docker-hubot-time.
Important notes
  • The first time you run the docker container, the image needs to be pulled from the public docker registry, which takes some time. Subsequent runs are super fast.
  • If you are not running Linux (i.e. if you are on a Mac or PC), you cannot use $PWD to mount the volumes. Instead, read the If you are using Boot2Docker... note to determine the absolute path where you must place the git-cloned directory.
Adding scripts
To include your own scripts, you can use the following Docker command:
-e HUBOT_NAME=bot \
-v $PWD/scripts:/home/hubot/scripts \
Deployment using Yeoman
Yeoman generator allows you to generate a Hubot bot using the Rocket.Chat adapter. Yeoman uses the latest versions of Hubot and Rocket.Chat adapter module, which enable asynchronous processing in ES6 Javascript, and introduce various bug fixes.
Development for different versions of adapter
v2.x.x
Standard
In a Hubot instance once hubot-rocketchat is added by npm or yarn, you can replace the package with a development version directly:
  • cd node_modules from the bot's project root
  • rm -rf hubot-rocketchat to delete the published version
  • git clone git@github.com:RocketChat/hubot-rocketchat.git to add dev version
  • cd hubot-rocketchat move to dev path
  • npm install install dependencies
Linked
Setting up a locally linked package is easier for continued development and/or using the same development version of the adapter in multiple bots.
  • Change directory to your development adapter path
  • npm link or yarn link to set the origin of the link
  • Change directory to your bot's project root
  • npm link hubot-rocketchat or yarn link hubot-rocketchat to create the link
v1.x.x and v0.x.x
Docker-compose
If you want to use docker-compose for this task, add this for v0.1.4 adapter (this must be inserted in your docker-compose.yml):
hubot:
image: rocketchat/hubot-rocketchat:v0.1.4
- ROCKETCHAT_URL=your-rocket-chat-instance-ip:3000 (e.g. 192.168.2.240:3000)
- ROCKETCHAT_ROOM=general
- RESPOND_TO_DM=true
- ROCKETCHAT_USER=username-of-your-bot
- ROCKETCHAT_PASSWORD=yourpass
- BOT_NAME=bot
- GOOGLE_API_KEY=yourgoogleapikey
- EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics,hubot-google,hubot-reddit,hubot-bofh,hubot-bookmark,hubot-shipit,hubot-maps
links:
- rocketchat:rocketchat
# this is used to expose the hubot port for notifications on the host on port 3001, e.g. for hubot-jenkins-notifier
ports:
- 3001:8080
If you want your bot to listen to all public rooms and all private rooms it is joined to, leave the env ROCKETCHAT_ROOM empty like in the example above and set the env LISTEN_ON_ALL_PUBLIC=true.
Please pay attention to some external scripts that are in the example above, as some of them need your Google-API-Key in the docker compose file.
Version information and compatibility
The examples above use Hubot v3 and Rocketchat.Chat adapter v2, using the new [Rocket.Chat JS SDK][sdk for Rocket.Chat instances 0.60.0 onward.
v2 contains major breaking changes. Starting with this version:
  • CoffeeScript BOTs will no longer be supported, all new bot scripts should be written in NodeJS 8 compatible JavaScript
  • Only Hubot v3 will be supported
  • Rocket.Chat Server version 0.63.0 or higher is supported
  • Yeoman generator support is discontinued, you should start your project with our hubot v3 boilerplate
  • NodeJS 8 or later is required for operations
  • The latest ES6 syntax in NodeJS 8, including the popular async-await, is fully supported
Hubot versions
Versions of hubot-rocketchat prior to v2 are incompatible with Hubot v3
This bot is written in ES6 and intended to run on Node v8+. To run a bot on older versions of Node would require compilation with Babel to use the full ES6 feature set.
Adapter versions
Older versions of the adapter (before v0.1.4) are incompatible with more recent versions of Rocket.Chat (v0.35+). Please report an issue, if you find specific version mismatch.
NOTE: releases between 0.35.0 and 0.37.1 are not recommended for hubot operations.
Rocket.Chat adapter v1 uses CoffeeScript, which makes extention of classes in JavaScript ES6 troublesome.
v1 versions of the adapter are only compatible with 0.37.1 and higher of Rocket.Chat Server. However, you should be able to continue using v1 adapter and CoffeeScript bots with the most up-to-date version of the server.
If you are writing CoffeeScript bots, you need Hubot v2.x and v1.x.x or v0.x.x of the adapter. Please see instructions for v1.x.x and v0.x.x of the adapter.
Additional information
For more examples on building and scripting your bot, please see Hubot documentation.
FAQ
Q: I am not trying to stage a denial of service attack, why would I ever want to write a bot? A: There are many positive and productive use cases for bots. Imagine a customer service support chat. As soon as a customer enters the support channel, a bot immediately identifies the customer and then:
  • fetches recent sales information from the sales dept server
  • fetches personal information from the customer data base
  • fetches latest notes made by her/his salesperson from the CRM system
  • scans the customer's facebook and twitter posts
  • obtains details of the last support ticket for this customer
Putting it altogether and then private message the service rep with the information.
Another use-case is a load test bot, imagine a bot that accepts the command:
rocketbot loadtest europe 25, asia 50, usa 100, canada 10
This command specifies a distribution of test bot instances, to be created across globally located data centers.
Once received, the bot:
  • parses the distribution
  • concurrently ssh to remote Kubernetes controllers and spawns the specified number of test bot instances to start the load test
Q: The architecture of hubot-rocketchat looks interesting, can you tell me more about it? A: Sure, it is based on hubot-meteorchat. hubot-meteorchat is the hubot integration project for Meteor based chats and real-time messaging systems. Its driver based architecture simplifies creation and customization of adapter for new systems. For example, the hubot-rocketchat integration is just hubot-meteorchat + Rocket.Chat driver.
Learn more about hubot-meteorchat and other available drivers at this link.
Contributions and discussions
Please see our documentation on contributing, then visit the issues to share your needs or ideas.
If you want to contribute to the development or improvement of this adapter, pull requests are welcome.
Feel free to join us in the #hubot channel to discuss hubot, and any scripts you might be working on.
