Manage Settings Using Environment Variables
Prev Next
Rocket.Chat allows you to manage workspace settings using environment variables instead of updating them through the admin UI or database. This approach is useful for automating deployments and maintaining consistent configurations across environments.
This guide explains how to configure settings with environment variables and outlines the supported data types.
Get a setting ID
To manage a setting using an environment variable, you need its setting ID.
Hover over a setting name in Administration > Workspace > Settings to view its ID in the tooltip.
Set environment variables
Each deployment method provides its own way to define environment variables. Refer to the appropriate guide:
  1. Docker: Refer to Set Rocket.Chat deployment environment variable on Docker.
  2. Kubernetes: Visit the Set Rocket.Chat deployment environment variable on Kubernetes guide.
  3. Podman: Go to Set Rocket.Chat deployment environment variable on Podman.
The examples in this guide follow the Docker setup.
Configure settings with environment variables
Using environment variables in Rocket.Chat, you can:
  • Set initial values for settings
  • Override existing values
  • Block settings from being changed
  • Hide settings
The following sections describe each option.
Set the initial value for a setting
To define a setting value when the server starts for the first time, use:
SETTING_ID=VALUE
For example:
FileUpload_Storage_Type: GoogleCloudStorage
This applies only if the setting has not been configured previously in the UI or database. If the setting already has a value, use Overwrite the setting value.
To overwrite an existing setting value, prefix the setting ID with OVERWRITE_SETTING_. For example:
OVERWRITE_SETTING_FileUpload_Storage_Type: GoogleCloudStorage
Settings defined with OVERWRITE_SETTING_ environment variables take precedence over changes made in the workspace UI. If you change a setting in the UI, its value will revert to the environment-defined value when the workspace restarts. To make a persistent change, update or remove the environment variable.
Block settings
To prevent a setting from being changed through the UI or API, use SETTINGS_BLOCKED with a comma-separated list of setting IDs. For example:
SETTINGS_BLOCKED: FileUpload_Storage_Type,FileUpload_GoogleStorage_AccessId,FileUpload_GoogleStorage_Secret
To unblock any setting, remove it from the list and restart your Rocket.Chat server.
Hide settings
To hide sensitive settings from appearing in the workspace UI, use the SETTINGS_HIDDEN variable with a comma-separated list of setting IDs you want to hide. For example:
SETTINGS_HIDDEN: FileUpload_GoogleStorage_AccessId,FileUpload_GoogleStorage_Secret
Use this command with extreme caution. Avoid hiding settings required by the Rocket.Chat client, such as FileUpload_Storage_Type, as this can break functionality.
Setting metadata and data types
To use environment variables effectively, it helps to understand the structure of each setting. Each setting includes metadata like its ID, type, default value, and visibility. When setting values via environment variables, you must use the correct data type—e.g., string, boolean, number, etc.
Basic settings
Name
Data Type
_id
SettingId = string
type
  • boolean
  • timezone
  • string
  • relativeUrl
  • password
  • int
  • select
  • multiSelect
  • language
  • color
  • font
  • code
  • action
  • asset
  • roomPick
  • group
  • date
public
boolean
env
boolean
group (Optional)
GroupId = SettingId
section (Optional)
SectionName = string
tab (Optional)
TabId = SettingId
i18nLabel
string
value
SettingValue can be one of the following types:
  • string
  • boolean
  • number
  • SettingValueMultiSelect
  • Date
  • AssetValue
  • undefined
packageValue
  • string
  • boolean
  • number
  • Date
  • AssetValue
  • undefined
blocked
boolean
enableQuery (Optional)
string
displayQuery (Optional)
string
sorter
number
properties (Optional)
unknown
enterprise (Optional)
boolean
requiredOnWizard (Optional)
boolean
hidden (Optional)
boolean
modules (Optional)
Array
invalidValue (Optional)
SettingValue can be one of the following values:
  • string
  • boolean
  • number
  • Date
  • AssetValue
  • undefined
valueSource (Optional)
string
secret (Optional)
boolean
i18nDescription (Optional)
string
autocomplete (Optional)
boolean
processEnvValue (Optional)
  • string
  • boolean
  • number
  • Date
  • AssetValue
  • undefined
meteorSettingsValue (Optional)
  • string
  • boolean
  • number
  • Date
  • AssetValue
  • undefined
ts
Date
createdAt
Date
_updatedAt (Optional)
Date
multiline (Optional)
boolean
values (Optional)
Array
placeholder (Optional)
string
wizard (Optional)
  • step: number
  • order: number
persistent (Optional)
boolean
readonly (Optional)
boolean
alert (Optional)
string
private (Optional)
boolean
Group settings
Name
Data Type
_id
string
hidden
boolean
blocked
boolean
ts
Date
sorter
number
i18nLabel
string
displayQuery
string
i18nDescription
string
value
undefined
type
group
alert
string
Enterprise settings
Name
Data Type
enterprise
true
invalidValue
  • string
  • boolean
  • number
  • Date
  • AssetValue
  • undefined
Color settings
Name
Data Type
type
color
editor
SettingEditor
packageEditor (Optional)
SettingEditor
Action settings
Name
Data Type
type
action
value
string
actionText (Optional)
string
Code settings
Name
Data Type
type
action
value
string
string
Asset settings
Name
Data Type
type
asset
value
AssetValue
fileConstraints
IRocketChatAssetConstraint
asset
string
SelectOption settings
Name
Data Type
key
The type can be:
  • string
  • number
i18nLabel
string
Editor settings
Name
Data Type
COLOR
color
EXPRESSION
expression
Date settings
Name
Data Type
type
Date
value
Date
Statistics settings
Name
Data Type
account2fa (Optional)
boolean
cannedResponsesEnabled (Optional)
boolean
e2e (Optional)
boolean
e2eDefaultDirectRoom (Optional)
boolean
e2eDefaultPrivateRoom (Optional)
boolean
smtpHost (Optional)
string
smtpPort (Optional)
string
fromEmail (Optional)
string
fileUploadEnable (Optional)
boolean
frameworkDevMode (Optional)
boolean
frameworkEnable (Optional)
boolean
surveyEnabled (Optional)
boolean
updateChecker (Optional)
boolean
liveStream (Optional)
boolean
broadcasting (Optional)
boolean
allowEditing (Optional)
boolean
allowDeleting (Optional)
boolean
allowUnrecognizedSlashCommand (Optional)
boolean
allowBadWordsFilter (Optional)
boolean
readReceiptEnabled (Optional)
boolean
readReceiptStoreUsers (Optional)
boolean
pushEnable (Optional)
boolean
globalSearchEnabled (Optional)
boolean
threadsEnabled (Optional)
boolean
bigBlueButton (Optional)
boolean
jitsiEnabled (Optional)
boolean
Environment variables provide a controlled way to manage workspace settings during deployment. Use them to define initial values, enforce overrides, and restrict or hide settings where necessary. Always ensure that values match the expected data type.
