Setting up Process Managers and Init Systems
    • Dark
      Light
    • PDF
    • Dark
      Light
    • PDF
    Article summary
    PM2
    Systemd
    Deploy Rocket.Chat to Linux that run on systemd (RedHat, Centos, Ubuntu, CoreOS and so on).
    How to run Rocket.Chat on systemd.
    First we need to create the unit file.
    vi /etc/systemd/system/rocketchat.service
    With the contents:
    [Unit]
    Description=Rocket.Chat Server
    After=network.target remote-fs.target nss-lookup.target mongod.target nginx.target  # Remove or Replace nginx with your proxy
    [Service]
    ExecStart=/usr/local/bin/node /var/www/rocketchat/main.js    # Specify the location of node and location of main.js
    Restart=always                                               # If set to always, the service will be restarted regardless of whether it exited cleanly or not, got terminated abnormally by a signal, or hit a timeout.
    RestartSec=10                                                # Restart service after 10 seconds if node service crashes
    StandardOutput=syslog                                        # Output to syslog
    StandardError=syslog                                         # Output to syslog
    SyslogIdentifier=nodejs-example
    #User=<alternate user>
    #Group=<alternate group>
    Environment=NODE_ENV=production PORT=3000 ROOT_URL=https://rocketchat.domain.com MONGO_URL=mongodb://localhost:27017/rocketchat
    [Install]
    WantedBy=multi-user.target
    Then you need to enable the service systemctl enable rocketchat.service
    To start the service systemctl start rocketchat.service
    To verify it is running systemctl status rocketchat.service
    Backup
    All data will be hourly backed up to /data/domains/example.org/data folder. We advise to copy this folder to a remote location in case of hardware failure.
    Upstart - Ubuntu
    Note: Upstart is no longer supported. We no longer support Ubuntu 14.04. If upgrading please see systemd or Ubuntu 18.04
    The following examples are upstart jobs which control automatic start-up and, if necessary, respawning of your Rocket.Chat app, as well as management of an optional Hubot chat-bot.
    In order to use the examples, simply copy each example and save into a file, paying attention to the fact that the filenames should be preserved unless you edit the examples to reflect any filename changes you make. Be sure to edit the environment variables, and possibly paths, according to your particular installation. Once you've saved the files to the proper directory (/etc/init) usage is as simple as rebooting.
    Which upstart management jobs that you use depend on what type of Rocket.Chat deployment you are using (docker-compose, non-docker, etc). A race condition exists with docker-compose, which requires that Mongo and the Rocket.Chat application be started independently, thus a slightly modified upstart job is required compared to non-docker instances.
    Non-docker-compose
    Save as: /etc/init/rocketchat.conf
    description "rocketchat application server"
    # Wait for mongod before starting rocketchat app
    start on (started mongod)
    stop on runlevel [!2345]
    # Automatically attempt to restart with finite limits
    respawn
    respawn limit 99 5
    # Export necessary variables and start the Applications / Services
    script
        export MONGO_URL=mongodb://localhost:27017/rocketchat
        export ROOT_URL=https://host.yourdomain.tld
        export PORT=3000
        exec /usr/local/bin/node /home/administrator/Rocket.Chat/main.js
    end script
    Save as: /etc/init/rocketchat_hubot.conf
    description "hubot launcher"
    # Wait for the rocketchat upstart job before starting hubot
    start on started rocketchat
    # Automatically Respawn with finite limits
    respawn
    respawn limit 99 5
    script
        # Wait until Rocket.Chat is up and listening to port tcp 3000
        until nc -z localhost 3000; do
            sleep 1
        done
        export ROCKETCHAT_ROOM=GENERAL
        export ROCKETCHAT_USER=bot_username
        export ROCKETCHAT_PASSWORD=bot_password
        # Change to the hubot directory
        cd /home/administrator/myhubot
        # Launch Hubot
        exec bin/hubot -a rocketchat
    end script
    Docker-compose
    Save as: /etc/init/rocketchat_mongo.conf
    description "MongoDB service manager for rocketchat"
    # Start MongoDB after docker is running
    start on (started docker)
    respawn
    respawn limit 99 5
    # Path to our app
    chdir /var/www/rocket.chat
    script
        # start mongoDB
        exec /usr/local/bin/docker compose up db
    end script
    Save as: /etc/init/rocketchat_app.conf
    description "Rocket.Chat service manager"
    # Start Rocket.Chat after mongo upstart job is running
    start on (started rocketchat_mongo)
    respawn
    respawn limit 99 5
    # Path to our app
    script
        # Bring up rocketchat app and hubot
        exec /usr/local/bin/docker compose up rocketchat hubot
    end script
    Was this article helpful?
    What's Next
    ESC
    Eddy AI, facilitating knowledge discovery through conversational intelligence
