Rocket.Chat allows you to manage workspace settings using environment variables. This is an efficient alternative to modifying settings directly through the admin UI or the database. This guide provides a comprehensive overview of how to manage settings using environmental variables and the data types for each kind of setting.
To manage a setting using an environment variable, you need its setting ID. The ID is displayed on tooltips when you hover over the setting’s name in your workspace.
Each recommended deployment method discusses how to set up these environment variables in its respective documentation. For Docker, these variables can be set within the environment section under the rocketchat service in your compose.yml file. Refer to the Kubernetes, Docker, and Snap documentation for specific setup instructions.
Configuring settings with environment variables
With environment variables in Rocket.Chat, you can:
- Set initial values for settings
- Override existing values
- Block settings from being changed
- Hide settings
Let’s look at each option in detail.
Set the initial value for a setting
To define the value of a setting for the first time when starting the server, add the environment variable SETTING_ID=VALUE. For example:
FileUpload_Storage_Type=hiGoogleCloudStorageThis only applies if the setting hasn't been previously configured in the UI or database. If the setting already has a value, use overwrite setting.
Overwrite the setting value
You can overwrite the value of any setting by using an environment variable prefixed with OVERWRITE_SETTING_<Setting Id>. For example:
OVERWRITE_SETTING_FileUpload_Storage_Type=GoogleCloudStorageSettings capable of this action can be seen when hovered in the Administration > Workspace > Settings section.
Block settings
To lock a setting and prevent it from being changed via the UI or API, use the SETTINGS_BLOCKED variable with a comma-separated list of setting IDs you want to block. For example:
SETTINGS_BLOCKED=FileUpload_Storage_Type,FileUpload_GoogleStorage_AccessId,FileUpload_GoogleStorage_SecretTo unblock any setting, remove it from the list and restart your Rocket.Chat server.
Hide settings
To hide sensitive settings from appearing in the workspace UI, use the SETTINGS_HIDDEN variable with a comma-separated list of setting IDs you want to hide: For example:
SETTINGS_HIDDEN=FileUpload_GoogleStorage_AccessId,FileUpload_GoogleStorage_SecretUse this command with extreme caution and avoid hiding any settings that the Rocket.Chat client depends on, for example
FileUpload_Storage_Type.
Setting metadata and data types
To use environment variables effectively, it helps to understand the structure of each setting. Each setting includes metadata like its ID, type, default value, and visibility. When setting values via environment variables, you must use the correct data type—e.g., string, boolean, number, etc.
Basic settings
| Name | Data Type |
 | boolean |
 | boolean |
 | string |
 | boolean |
 | string |
 | string |
 | number |
 | unknown |
 | boolean |
 | boolean |
 | boolean |
 | Array |
 | string |
 | boolean |
 | string |
 | boolean |
 | Date |
 | Date |
 | Date |
 | boolean |
 | Array |
 | string |
 | boolean |
 | boolean |
 | string |
 | boolean |
Group settings
| Name | Data Type |
 | string |
 | boolean |
 | boolean |
 | Date |
 | number |
 | string |
 | string |
 | string |
 | undefined |
 | group |
 | string |
Enterprise settings
| Name | Data Type |
 | true |
Color settings
| Name | Data Type |
 | color |
 | SettingEditor |
 | SettingEditor |
Action settings
| Name | Data Type |
 | action |
 | string |
 | string |
Code settings
| Name | Data Type |
 | action |
 | string |
 | string |
Asset settings
| Name | Data Type |
 | asset |
 | AssetValue |
 | IRocketChatAssetConstraint |
 | string |
SelectOption settings
| Name | Data Type |
 | The type can be:
 | string |
Editor settings
| Name | Data Type |
 | color |
 | expression |
Date settings
| Name | Data Type |
 | Date |
 | Date |
Statistics settings
| Name | Data Type |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | string |
 | string |
 | string |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
 | boolean |
