This article outlines features that are no longer supported in Rocket.Chat or are scheduled for removal in future updates (deprecated). It also serves as an early notice for workspace administrators to adjust and optimize their workspaces accordingly. Please note that this information is subject to change with future releases and may not include every deprecated feature.
Breaking changes in upcoming versions
Rocket.Chat v9.0.0
Removal of deprecated features
In Rocket.Chat 9.0.0 and later, LDAP, SAML, and Custom OAuth require a premium plan, and Atlassian Crowd and the Drupal, Facebook, GitHub Enterprise, LinkedIn, Meteor, X (formerly Twitter), WordPress, and Dolphin logins have been removed on all plans. Before updating, Community workspaces that use LDAP, SAML, or Custom OAuth must upgrade their plan or move users to an authentication method available in Community, and workspaces on any plan must move users who sign in with a removed login to another method. Otherwise, these users are unable to log in after the update.
The Gravatar integration for Set Default Avatar in the Accounts settings, deprecated in version 8.9.0, has been removed in version 9.0.0. New users get an uploaded or OAuth avatar, or their initials. Avatars already stored from Gravatar are kept.
The Allow Anonymous Write feature in the Accounts settings, deprecated in version 8.3.0, has been removed in version 9.0.0, together with the
anonymousrole. Existing anonymous users are deactivated on upgrade. Anonymous read is still available.The Babel transcompiler for integrations has been removed in version 9.0.0. Scripts are stored as-is and executed natively by
isolated-vm(V8). For details, see Integrations.WebDAV integration removed: The WebDAV integration, its settings, the WebDAV accounts in user preferences, and WebDAV file storage have been removed. The upgrade stops if Storage Type is set to WebDAV: switch to GridFS, Amazon S3, Google Cloud Storage, or FileSystem and move your files before you update.
Atlassian Crowd integration removed: The Atlassian Crowd settings, login, and user sync have been removed. Users provisioned through Crowd keep their accounts and must sign in another way, such as LDAP (Crowd exposes an LDAP interface) or a local password.
OAuth login providers removed: The built-in Drupal, Facebook, GitHub Enterprise, LinkedIn, Meteor, X (formerly Twitter), WordPress, and Dolphin logins have been removed, and their settings are deleted on upgrade. Apple, GitHub, GitLab, Google, and Nextcloud remain. Providers that support standard OAuth2 can be set up again as Custom OAuth.
Legacy OAuth flow removed: OAuth sign-in always uses the server-side flow. The Use Modern OAuth Flow setting and the OAuth Proxy Host and Proxy Services settings have been removed.
LDAP, SAML, and Custom OAuth on Community: LDAP, SAML, and Custom OAuth require a license that includes the
ldap-enterprise,saml-enterprise, oroauth-enterprisemodule. On workspaces without it, these sign-in options are turned off.Legacy push settings removed: The hidden
Push_UseLegacy,Push_gcm_project_number, andPush_gcm_api_keysettings have been removed. Android push notifications use the push gateway or the FCM credentials in Google API Credentials.Legacy federation settings removed: The settings of the legacy federation and the Matrix bridge, and the
/federationslash command, have been removed. Use Federation instead.Unused settings removed: The hidden
Troubleshoot_Disable_Statistics_Generator,Troubleshoot_Disable_Workspace_Sync, andFileUpload_S3_SignatureVersionsettings have been removed.Use Rocket.Chat SDK setting removed: The Use Rocket.Chat SDK setting in the General settings has been removed. The web client always connects to the server through the SDK, so the setting no longer had any effect. It is deleted on upgrade.
Meteor client packages removed from the web client: The web client no longer includes Meteor's client packages. Scripts that run in the web client, such as the scripts in Manage → Workspace → Settings → Layout → Custom scripts and integration scripts that inject JavaScript, can no longer use
Meteor.userId(),Meteor.user(),Meteor.call(),Meteor.subscribe(),Meteor.loginWithToken(),Meteor.status(),Tracker, or client-side collections. The custom script events still fire onwindow. Scripts that need the current user can readMeteor.userIdandMeteor.loginTokenfromlocalStorage(or fromsessionStoragewhen Forget user session on window close is enabled) and call the REST API.ALLOW_UNSAFE_QUERY_AND_FIELDS_API_PARAMSremoved: The environment variable and thequeryandfieldsAPI parameters it re-enabled have been removed. Endpoints that validate their parameters return400 error-invalid-paramswhen a request includes them.Legacy
/ufsfile path removed: Files and avatars are no longer served from the legacy/ufspath. Use the file URLs returned by the REST API.API endpoint replacements and removals: The following deprecated API methods and endpoints have been removed, with some being replaced by improved alternatives:
Type
Name
Replacement
Deprecated since
Removed in version
Method
autoTranslate.getProviderUiMetadataReplaced by the /autotranslate.getProviderUiMetadata endpoint.
8.9.0
9.0.0
Method
cloud:getWorkspaceRegisterDataReplaced by the /cloud.workspaceRegisterData endpoint.
8.9.0
9.0.0
Method
getSetupWizardParametersReplaced by the /setupWizard.parameters endpoint.
8.9.0
9.0.0
Method
loadSurroundingMessagesReplaced by the
aroundIdparameter in the /rooms.history endpoint.8.9.0
9.0.0
Method
loadNextMessagesReplaced by the /rooms.history endpoint.
8.9.0
9.0.0
Method
loadHistoryReplaced by the /rooms.history endpoint.
8.9.0
9.0.0
Method
getMessagesReplaced by the /chat.getMessages endpoint
8.9.0
9.0.0
Method
raix:push-setuserNo replacement.
8.9.0
9.0.0
Method
getRoomJoinCodeNo replacement.
8.9.0
9.0.0
Method
checkFederationConfigurationNo replacement.
8.9.0
9.0.0
Method
afterVerifyEmailReplaced by the /users.verifyEmail endpoint.
8.7.0
9.0.0
Method
cloud:connectWorkspaceReplaced by the /cloud.connectWorkspace endpoint.
8.7.0
9.0.0
Method
authorization:addPermissionToRoleReplaced by the /permissions.addRole endpoint.
8.7.0
9.0.0
Method
authorization:removeRoleFromPermissionReplaced by the /permissions.removeRole endpoint.
8.7.0
9.0.0
Method
clearIntegrationHistoryReplaced by the /integrations.clearHistory endpoint.
8.7.0
9.0.0
Method
replayOutgoingIntegrationReplaced by the /integrations.replayOutgoing endpoint
8.7.0
9.0.0
Method
license:isEnterpriseReplaced by the /licenses.info endpoint.
8.6.0
9.0.0
Method
license:getModulesReplaced by the /licenses.info endpoint.
8.6.0
9.0.0
Method
banner/dismissReplaced by the /banners.dismiss endpoint.
8.6.0
9.0.0
Method
slashCommandReplaced by the /commands.run endpoint.
8.6.0
9.0.0
Method
e2e.resetOwnE2EKeyReplaced by the /users.resetE2EKey endpoint.
8.6.0
9.0.0
Method
deleteCustomSoundReplaced by the /custom-sounds.delete endpoint.
8.6.0
9.0.0
Method
blockUser/unblockUserReplaced by the /im.blockUser endpoint.
8.6.0
9.0.0
Method
saveSettingsReplaced by the POST /settings endpoint.
8.6.0
9.0.0
Method
e2e.requestSubscriptionKeysReplaced by the /e2e.requestSubscriptionKeys endpoint.
8.6.0
9.0.0
Method
autoTranslate.saveSettingsReplaced by the /autotranslate.saveSettings endpoint
8.6.0
9.0.0
Method
cloud:checkRegisterStatusReplaced by the /cloud.registrationStatus endpoint.
8.6.0
9.0.0
Method
createDiscussionReplaced by the /rooms.createDiscussion endpoint.
8.6.0
9.0.0
Method
e2e.fetchMyKeysReplaced by the /e2e.fetchMyKeys endpoint.
8.6.0
9.0.0
Method
e2e.setUserPublicAndPrivateKeysReplaced by the /e2e.setUserPublicAndPrivateKeys endpoint.
8.6.0
9.0.0
Method
deleteEmojiCustomReplaced by the /emoji-custom.delete endpoint.
8.6.0
9.0.0
Method
insertOrUpdateEmojiReplaced by the /emoji-custom.create and /emoji-custom.update endpoints.
8.6.0
9.0.0
Method
uploadEmojiCustomReplaced by the /emoji-custom.create endpoint.
8.6.0
9.0.0
Method
downloadPublicImportFileReplaced by the /downloadPublicImportFile endpoint.
8.6.0
9.0.0
Method
getImportFileDataReplaced by the /getImportFileData endpoint.
8.6.0
9.0.0
Method
getImportProgressReplaced by the /getImportProgress endpoint.
8.6.0
9.0.0
Method
getLatestImportOperationsReplaced by the /getLatestImportOperations endpoint.
8.6.0
9.0.0
Method
startImportReplaced by the /startImport endpoint.
8.6.0
9.0.0
Method
uploadImportFileReplaced by the /uploadImportFileendpoint.
8.6.0
9.0.0
Method
addIncomingIntegrationReplaced by the /integrations.create endpoint.
8.6.0
9.0.0
Method
deleteIncomingIntegrationReplaced by the /integrations.remove endpoint.
8.6.0
9.0.0
Method
updateIncomingIntegrationReplaced by the /integrations.update endpoint.
8.6.0
9.0.0
Method
addOutgoingIntegrationReplaced by the /integrations.create endpoint.
8.6.0
9.0.0
Method
deleteOutgoingIntegrationReplaced by the /integrations.remove endpoint.
8.6.0
9.0.0
Method
updateOutgoingIntegrationReplaced by the /integrations.update endpoint.
8.6.0
9.0.0
Method
addUsersToRoomReplaced by the /channels.invite and /groups.invite endpoints.
8.6.0
9.0.0
Method
archiveRoomReplaced by the /channels.archive endpoint.
8.6.0
9.0.0
Method
createChannelReplaced by the /channels.create endpoint.
8.6.0
9.0.0
Method
deleteUserOwnAccountReplaced by the /users.deleteOwnAccount endpoint.
8.6.0
9.0.0
Method
getChannelHistoryReplaced by the /channels.history endpoint.
8.6.0
9.0.0
Method
getUsernameSuggestionReplaced by the /users.getUsernameSuggestion endpoint.
8.6.0
9.0.0
Method
saveSettingReplaced by the /settings/:_id endpoint.
8.6.0
9.0.0
Method
setEmailReplaced by the /users.updateOwnBasicInfo endpoint.
8.6.0
9.0.0
Method
setRealNameReplaced by the /users.updateOwnBasicInfo endpoint.
8.6.0
9.0.0
Method
unarchiveRoomReplaced by the /channels.unarchive endpoint.
8.6.0
9.0.0
Method
sendMessageLivechatReplaced by the /livechat/message endpoint.
8.6.0
9.0.0
Method
getUserMentionsByChannelReplaced by the /channels.getAllUserMentionsByChannel endpoint.
8.6.0
9.0.0
Method
unreadMessagesReplaced by the /subscriptions.unread endpoint.
8.6.0
9.0.0
Method
pinMessageReplaced by the /chat.pinMessage endpoint
8.6.0
9.0.0
Method
unpinMessageReplaced by the /chat.unPinMessage endpoint
8.6.0
9.0.0
Method
deleteOAuthAppReplaced by the /oauth-apps.delete endpoint.
8.6.0
9.0.0
Method
updateOAuthAppReplaced by the /oauth-apps.update endpoint.
8.6.0
9.0.0
Method
saveNotificationSettingsReplaced by the /rooms.saveNotification endpoint.
8.6.0
9.0.0
Method
raix:push-updateReplaced by the /push.token endpoint.
8.6.0
9.0.0
Method
getStatisticsReplaced by the /statistics endpoint.
8.6.0
9.0.0
Method
followMessageReplaced by the /chat.followMessage endpoint.
8.6.0
9.0.0
Method
getThreadsListReplaced by the /chat.getThreadsList endpoint.
8.6.0
9.0.0
Method
unfollowMessageReplaced by the /chat.unfollowMessage endpoint
8.6.0
9.0.0
Method
deleteCustomUserStatusReplaced by the /custom-user-status.delete endpoint.
8.6.0
9.0.0
Method
getUserStatusTextReplaced by the /users.presence endpoint.
8.6.0
9.0.0
Method
insertOrUpdateUserStatusReplaced by the /custom-user-status.create and /custom-user-status.update endpoints.
8.6.0
9.0.0
Method
license:hasLicenseReplaced by the /licenses.info endpoint.
8.6.0
9.0.0
Method
license:getTagsReplaced by the /licenses.info endpoint.
8.6.0
9.0.0
Method
addAllUserToRoomReplaced by the /channels.addAll and /groups.addAll endpoints.
8.6.0
9.0.0
Method
addRoomLeaderReplaced by the /channels.addLeader and /groups.addLeader endpoints.
8.6.0
9.0.0
Method
addRoomModeratorReplaced by the /channels.addModerator and /groups.addModerator endpoints.
8.6.0
9.0.0
Method
addRoomOwnerReplaced by the /channels.addOwner and /groups.addOwner endpoints.
8.6.0
9.0.0
Method
browseChannelsReplaced by the /directory endpoint.
8.6.0
9.0.0
Method
channelsListReplaced by the /channels.list endpoint.
8.6.0
9.0.0
Method
deleteUserReplaced by the /users.delete endpoint.
8.6.0
9.0.0
Method
getRoomIdByNameOrIdReplaced by the /rooms.info endpoint.
8.6.0
9.0.0
Method
getRoomNameByIdReplaced by the /rooms.info endpoint.
8.6.0
9.0.0
Method
getTotalChannelsReplaced by the /channels.list endpoint.
8.6.0
9.0.0
Method
hideRoomReplaced by the /rooms.hide endpoint.
8.6.0
9.0.0
Method
ignoreUserReplaced by the /chat.ignoreUser endpoint.
8.6.0
9.0.0
Method
messageSearchReplaced by the /chat.search endpoint
8.6.0
9.0.0
Method
removeRoomLeaderReplaced by the /channels.removeLeader and /groups.removeLeader endpoints.
8.6.0
9.0.0
Method
removeRoomModeratorReplaced by the /channels.removeModerator and /groups.removeModerator endpoints.
8.6.0
9.0.0
Method
removeRoomOwnerReplaced by the /channels.removeOwner and /groups.removeOwner endpoints.
8.6.0
9.0.0
Method
removeUserFromRoomReplaced by the /channels.kick and /groups.kick endpoints.
8.6.0
9.0.0
Method
resetAvatarReplaced by the /users.resetAvatar endpoint.
8.6.0
9.0.0
Method
saveUserPreferencesReplaced by the /users.setPreferences endpoint.
8.6.0
9.0.0
Method
toggleFavoriteReplaced by the /rooms.favorite endpoint.
8.6.0
9.0.0
Method
UserPresence:setDefaultStatusReplaced by the /users.setStatus endpoint.
8.6.0
9.0.0
Method
joinRoomReplaced by the /rooms.join endpoint.
8.6.0
9.0.0
Method
deleteFileMessageReplaced by the /chat.delete endpoint.
8.6.0
9.0.0
Method
userSetUtcOffsetReplaced by the /users.setPreferences endpoint.
8.6.0
9.0.0
Method
spotlightReplaced by the /spotlight endpoint.
8.6.0
9.0.0
Method
listCustomSoundsReplaced by the /custom-sounds.list endpoint.
8.6.0
9.0.0
Method
leaveRoomReplaced by the /channels.leave, /groups.leave, /im.leave endpoints.
8.6.0
9.0.0
Method
requestDataDownloadReplaced by the /users.requestDataDownload endpoint.
8.6.0
9.0.0
Method
2fa:checkCodesRemainingReplaced by the /users.totpCodesRemaining endpoint.
8.8.0
9.0.0
Method
2fa:disableReplaced by the /users.disableTotp endpoint.
8.8.0
9.0.0
Method
2fa:enableReplaced by the /users.enableTotp endpoint.
8.8.0
9.0.0
Method
2fa:regenerateCodesReplaced by the /users.regenerateTotpCodes endpoint.
8.8.0
9.0.0
Method
2fa:validateTempTokenReplaced by the /users.validateTotp endpoint.
8.8.0
9.0.0
Method
addOAuthServiceReplaced by the /settings.addCustomOAuth endpoint.
8.8.0
9.0.0
Method
addSamlServiceNo replacement.
9.0.0
Method
addUserToRoomReplaced by the /channels.invite and /groups.invite endpoints.
8.6.0
9.0.0
Method
addWebdavAccountNo replacement.
9.0.0
Method
addWebdavAccountByTokenNo replacement.
9.0.0
Method
auditGetAuditionsReplaced by the /audit.auditions endpoint.
8.8.0
9.0.0
Method
auditGetMessagesReplaced by the /audit.messages endpoint.
8.8.0
9.0.0
Method
auditGetOmnichannelMessagesReplaced by the /audit.omnichannelMessages endpoint.
8.8.0
9.0.0
Method
autoTranslate.getSupportedLanguagesReplaced by the /autotranslate.getSupportedLanguages endpoint.
9.0.0
Method
autoTranslate.translateMessageReplaced by the /autotranslate.translateMessage endpoint.
9.0.0
Method
botRequestNo replacement.
9.0.0
Method
cleanRoomHistoryReplaced by the /rooms.cleanHistory endpoint.
9.0.0
Method
cloud:checkUserLoggedInNo replacement.
9.0.0
Method
cloud:finishOAuthAuthorizationNo replacement.
9.0.0
Method
cloud:getOAuthAuthorizationUrlNo replacement.
9.0.0
Method
cloud:logoutNo replacement.
9.0.0
Method
cloud:registerWorkspaceNo replacement.
9.0.0
Method
cloud:syncWorkspaceReplaced by the
/cloud.syncWorkspaceendpoint.-
9.0.0
Method
createDirectMessageReplaced by the
/im.createendpoint.-
9.0.0
Method
createPrivateGroupReplaced by the /groups.create endpoint.
9.0.0
Method
crowd_sync_usersNo replacement.
9.0.0
Method
crowd_test_connectionNo replacement.
9.0.0
Method
e2e.getUsersOfRoomWithoutKeyReplaced by the /e2e.getUsersOfRoomWithoutKey endpoint.
9.0.0
Method
e2e.setRoomKeyIDReplaced by the /e2e.setRoomKeyID endpoint.
9.0.0
Method
executeSlashCommandPreviewReplaced by the /commands.preview endpoint.
9.0.0
Method
getFileFromWebdavNo replacement.
9.0.0
Method
getReadReceiptsReplaced by the /chat.getMessageReadReceipts endpoint.
8.8.0
9.0.0
Method
getRoomByIdReplaced by the /rooms.info endpoint.
9.0.0
Method
getS3FileUrlNo replacement.
9.0.0
Method
getSingleMessageReplaced by the /chat.getMessage endpoint.
9.0.0
Method
getSlashCommandPreviewsReplaced by the /commands.preview endpoint.
9.0.0
Method
getThreadMessagesReplaced by the /chat.getThreadMessages endpoint.
8.8.0
9.0.0
Method
getUsersOfRoomReplaced by the /channels.members and /groups.members endpoints.
9.0.0
Method
getWebdavFileListNo replacement.
9.0.0
Method
getWebdavFilePreviewNo replacement.
9.0.0
Method
insertOrUpdateSoundReplaced by the /custom-sounds.create and /custom-sounds.update endpoints.
8.5.0
9.0.0
Method
joinDefaultChannelsNo replacement.
9.0.0
Method
listCustomUserStatusReplaced by the /custom-user-status.list endpoint.
9.0.0
Method
loadLocaleNo replacement.
9.0.0
Method
loadMissedMessagesReplaced by the /chat.syncMessages endpoint.
8.8.0
9.0.0
Method
logoutCleanUpReplaced by the /users.logout endpoint.
8.7.0
9.0.0
Method
messages/getNo replacement.
9.0.0
Method
OAuth.retrieveCredentialNo replacement.
9.0.0
Method
openRoomNo replacement.
9.0.0
Method
personalAccessTokens:generateTokenReplaced by the /users.generatePersonalAccessToken endpoint.
9.0.0
Method
personalAccessTokens:regenerateTokenReplaced by the /users.regeneratePersonalAccessToken endpoint.
9.0.0
Method
personalAccessTokens:removeTokenReplaced by the /users.removePersonalAccessToken endpoint.
9.0.0
Method
push_testReplaced by the /push.test endpoint.
8.8.0
9.0.0
Method
readMessagesReplaced by the /subscriptions.read endpoint.
9.0.0
Method
readThreadsReplaced by the /chat.readThread endpoint.
8.8.0
9.0.0
Method
refreshOAuthServiceReplaced by the /settings.refreshOAuthServices endpoint.
8.8.0
9.0.0
Method
registerUserReplaced by the /users.register endpoint.
9.0.0
Method
removeOAuthServiceReplaced by the /settings.removeCustomOAuth endpoint.
8.8.0
9.0.0
Method
rocketchatSearch.suggestNo replacement.
9.0.0
Method
saveAudioNotificationValueNo replacement.
9.0.0
Method
saveRoomSettingsReplaced by the /rooms.saveRoomSettings endpoint.
9.0.0
Method
sendFileMessageReplaced by the
/rooms.media/:ridendpoint.8.4.0
9.0.0
Method
sendForgotPasswordEmailReplaced by the /users.forgotPassword endpoint.
9.0.0
Method
sendMessageReplaced by the /chat.sendMessage endpoint.
8.8.0
9.0.0
Method
setAvatarFromServiceReplaced by the /users.setAvatar endpoint.
8.7.0
9.0.0
Method
setUserActiveStatusReplaced by the /users.setActiveStatus endpoint.
9.0.0
Method
starMessageReplaced by the /chat.starMessage endpoint.
8.0.0
9.0.0
Method
updateMessageReplaced by the /chat.update endpoint.
9.0.0
Method
uploadCustomSoundReplaced by the /custom-sounds.create endpoint.
8.5.0
9.0.0
Method
uploadFileToWebdavNo replacement.
9.0.0
Endpoint
webdav.getMyAccountsNo replacement.
9.0.0
Endpoint
webdav.removeWebdavAccountNo replacement.
9.0.0
Endpoint
DELETE /canned-responses(ID in the request body)Replaced by the DELETE /canned-responses/:_id endpoint.
8.0.0
9.0.0
Endpoint
POST /loginwith an OAuthserviceNameandaccessTokenSigning in with a Google, Facebook, or Twitter access token has been removed. Use the OAuth sign-in flow and the /loginCode.redeem endpoint.
9.0.0
API parameter replacements and removals: The following deprecated API parameters have been removed in 9.0.0 to mitigate security risks and improve performance.
Type
Name
Parameter affected
Deprecated since
Removed in version
Endpoint
skipTranspileRemoved with the Babel transcompiler for integrations.
8.4.0
9.0.0
Endpoint
fieldsRemoved to avoid malicious queries.
5.0.0
9.0.0
Endpoint
queryRemoved to avoid malicious queries.
5.0.0
9.0.0
Endpoint
livechat/department.autocomplete and livechat/visitors.autocomplete
conditionsinselectorRemoved to avoid unsafe queries.
8.8.0
9.0.0
Endpoint
users.info, users.create, and users.update
freeSwitchExtensionRenamed to
sipExtension, also in user objects returned by the API.-
9.0.0
Endpoint
users.create, users.update, users.updateOwnBasicInfo, and users.info
phonesReplaced by the
phonesarray ({ number, label? }), also in user objects returned by the API. Existing numbers are migrated on upgrade.-
9.0.0
Endpoint
token(response)The response returns flat
tokenTypeandtokenValuefields instead of thetokenobject. Request bodies are unchanged.-
9.0.0
Endpoint
_idThe
_idparameter is now required.-
9.0.0
Rocket.Chat v8.0.0
Architectural and database updates
⚠️ We have officially discontinued support for MongoDB versions 5.0 and 6.0 to mitigate security risks as they have reached their official end-of-life (EOL). Workspaces running either version are required to upgrade to MongoDB 8.2 before moving to Rocket.Chat v8.0.0. It is important to back up your data before this upgrade to prevent unintentional data loss or potential service disruptions.
The Streamhub service and the deprecated
DISABLE_DB_WATCHERSenvironment variable have been removed as part of ongoing efforts to simplify the platform architecture and deployment model. Streamhub is no longer required for real-time communication in current workspace setups. You can safely remove the streamhub microservice andDISABLE_DB_WATCHERSfrom your configuration.
Omnichannel and marketplace enhancements
We have pruned unused SMS integrations, specifically eliminating the settings for Mobex and VoxTelesys. Twilio will remain the only supported integration available for configuring SMS gateways in your workspace.
WebRTC-based Livechat calls and all associated features, including the Meet page, are outdated and have been removed. Workspaces that require synchronous communication in Omnichannel can integrate video conferencing solutions through Apps-Engine or the Rocket.Chat APIs.
The outdated Game Center feature has been removed to reduce clutter, as games are no longer available on the marketplace.
Security and administration changes
Tokenpass OAuth integration is no longer available on the workspace. If your workspace still relies on Tokenpass for user authentication, update your configurations to use a supported alternative OAuth or SAML provider to avoid potential authentication issues and locking users out.
Enable second layer encryption for data transport setting is discontinued and no longer available.
The Logs tab in Reports has been removed. Log View Limit settings and log streaming features, including stdout streaming, related APIs, permissions, and runtime log queues are now cleared from the codebase. This change addresses the security and reliability limitations of the built-in app log view, especially in multi-instance and microservices production setups. Workspace logging is now handled exclusively at the infrastructure level. Visit Monitor Workspace Logs and Metrics for more details.
The previously deprecated
/v1/users.createTokenendpoint has been undeprecated and is no longer scheduled for removal. It now enforces additional security requirements where administrators must configure theCREATE_TOKENS_FOR_USERS_SECRETenvironment variable and include this shared secret in all requests to restrict token generation to authorized users.While the
/v1/users.createTokenendpoint is being retained, theusers.createTokenmethod has been removed.The
/v1/e2e.updateGroupKeyendpoint has been undeprecated. It is no longer marked for deprecation and will continue to be supported within the workspace.
Rocket.Chat Voice improvements
With the launch of the new Rocket.Chat Voice architecture, the deprecated VoIP architecture that relied on the old FreeSwitch integration has been being completely cleared from the codebase. This change does not eliminate FreeSwitch compatibility. Instead, the deprecated FreeSwitch Integration is being replaced with a generic SIP integration that remains fully compatible with FreeSwitch and other SIP-compliant infrastructures.
Due to this removal, workspaces relying on the legacy integration must prepare for the following:
FreeSwitch components removed: The old VoIP integration with FreeSwitch has been removed. This includes all associated technical components, such as extension management APIs and the collection of VoIP statistics related to FreeSwitch connections and extensions.
New settings for routing calls: Legacy settings such as the FreeSwitch Integration section and Team Voice Calls Enabled setting have been removed from the workspace UI. Rocket.Chat Voice is now automatically enabled when the Voice add-on is active, allowing intra-workspace calls via standard WebRTC without additional configuration. A dedicated SIP Integration setting is now available for routing calls through external SIP infrastructure.
VoIP permission changes: The legacy permissions
Manage Voice Calls,View Voice Call Extensions, andAllow Voice Callhave been removed. Granular permissions have been introduced to grant access to internal and external calling features in the new Rocket.Chat Voice architecture.
Several deprecated features will be removed in v8.0.0 to simplify the codebase, improve performance, and mitigate security risks.
Current Chats removal: The Current Chats page in Omnichannel has been removed in favor of the Contact Center, which serves as the unified interface for managing chats, contacts, and calls.
OTR feature removed: We have removed the Off-the-Record (OTR) messaging feature designed for exchanging temporary client-side encrypted messages, due to low adoption. For encrypted messaging, consider using End-to-End Encryption (E2EE). E2EE provides improved encryption capabilities that align better with the platform’s core security features.
Omnichannel Voice Channel (VoIP) removed: The legacy Omnichannel Voice channel feature has been removed, along with its associated API endpoints and permissions. Its Asterisk-based implementation does not support highly scalable, cloud-native VoIP workloads. For voice requirements in Omnichannel, consider integrating scalable VoIP providers or call-center platforms using supported APIs or extensions. Rocket.Chat can also be embedded into third-party call-center solutions using Chat Engine, enabling chat-based communication with your existing VoIP infrastructure.
WebRTC admin settings removed: The WebRTC workspace administration settings are no longer in use and have been removed completely.
Type | Name | Replacement | Deprecated since | Removed in version |
Endpoint |
| No replacement; the functionality is no longer supported. | 8.0.0 | 8.0.0 |
Endpoint |
| No replacement. | 8.0.0 | 8.0.0 |
Method |
| Replaced by the /livechat/business-hours.save endpoint. | 8.0.0 | 8.0.0 |
Method |
| Replaced by livechat/monitors.create endpoint. | 8.0.0 | 8.0.0 |
Method |
| Replaced by the /livechat/business-hours.remove endpoint. | 8.0.0 | 8.0.0 |
Method |
| Replaced by the /livechat/monitors.delete endpoint. | 8.0.0 | 8.0.0 |
Method |
| Replaced by the POST /livechat/tags.save endpoint. | 8.0.0 | 8.0.0 |
Endpoint |
| The
| 8.0.0 | 8.0.0 |
Method |
| Replaced by the /livechat/units endpoint. | 7.13.0 | 8.0.0 |
Endpoint |
| Extensions can now be assigned in /users.update endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the POST /canned-responses endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the /livechat/tags.delete endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the livechat/upload/:rid endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the /livechat/inquiries.returnAsInquiry endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the livechat/rooms.delete endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the DELETE /canned-responses/:_id endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the DELETE /livechat/units/{id} endpoint. | 7.12.0 | 8.0.0 |
Method |
| Replaced by the /livechat/inquiries.take endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/department endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/transcript endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/custom-fields.save endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/rooms.removeAllClosedRooms endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the livechat/config/routing endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/analytics/dashboards/charts-data endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/agents.saveInfo endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /livechat/custom-fields.delete endpoint. | 7.11.0 | 8.0.0 |
Method |
| No replacement; the functionality is no longer supported. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /roles.addUserToRole or /roles.removeUserFromRole endpoint. | 7.11.0 | 8.0.0 |
Method |
| Replaced by the /rooms.roles endpoint. | 7.10.0 | 8.0.0 |
Method |
| Replaced by the /roles.getUsersInPublicRoles endpoint. | 7.10.0 | 8.0.0 |
Method |
| Replaced by the /users.updateOwnBasicInfo endpoint. | 7.10.0 | 8.0.0 |
Method |
Method |
| Replaced by the /chat.react endpoint. | 7.10.0 | 8.0.0 |
Method |
Method |
Method |
| Replaced by the /roles.removeUserFromRole endpoint. | 7.10.0 | 8.0.0 |
Method |
| Replaced by the /roles.delete endpoint. | 7.10.0 | 8.0.0 |
Method |
| Replaced by the /roles.addUserToRole endpoint. | 7.10.0 | 8.0.0 |
Method |
| No replacement; the functionality is no longer supported. | 7.4.0 | 8.0.0 |
Endpoint |
| Replaced by the /rooms.media/:rid endpoint | 6.10.0 | 8.0.0 |
Endpoint |
| Replaced by the /banners/:id or /banners endpoint. | 6.10.0 | 8.0.0 |
Method |
| Replaced by the /rooms.muteUser endpoint. | 6.8.0 | 8.0.0 |
Method |
| Replaced by the /rooms.unmuteUser endpoint. | 6.8.0 | 8.0.0 |
Method |
| This method will be removed. | 6.8.0 | 8.0.0 |
Method |
| Users upsert no longer allowed. Replaced by /users.create endpoint. | 6.7.0 | 8.0.0 |
Method |
| Replaced by the /livechat/room.resumeOnHold endpoint. | 6.3.0 | 8.0.0 |
Method |
| Replaced by the /livechat/room.close endpoint | 6.0.0 | 8.0.0 |
Method |
| Replaced by the /livechat/agent.status endpoint. | 5.4.0 | 8.0.0 |
Method |
| Replaced by the /users.getAvatarSuggestion endpoint. | 5.4.0 | 8.0.0 |
Method |
| Replaced by the /users.sendConfirmationEmail endpoint. | 5.4.0 | 8.0.0 |
Method |
| Replace by the /livechat/tags endpoint. | 5.2.0 | 8.0.0 |
Method |
| No replacement; the functionality is no longer supported. | 5.2.0 | 8.0.0 |
Method |
Method |
| Replaced by the /livechat/room.forward endpoint. | 5.1.0 | 8.0.0 |
Method |
| Replaced by users.sendConfirmationEmail endpoint. | 5.4.0 | 8.0.0 |
API parameter removals: The following parameters have been permanently removed from their respective API endpoints in v8.0.0:
Type | Name | Parameter affected | Description | Deprecated since | Removed in version |
Endpoint | hideRoomsWithNoActivity | The endpoint no longer accepts | 6.11.0 | 8.0.0 | |
Endpoint | appId | This parameter will no longer be accepted (use clientId or _id instead). | 6.0.0 | 8.0.0 | |
Endpoint | role | The role parameter will still be used, but its value must now always be the role ID. Querying with the role name as value is deprecated. | 4.6.0 | 8.0.0 | |
Endpoint | roleName | This parameter will no longer be accepted. Use | 4.6.0 | 8.0.0 | |
These changes are vital for ensuring the long-term stability and security of the Rocket.Chat workspaces. Workspace administrators should begin evaluating their current configurations now to facilitate a seamless upgrade to version 8.0.0. For detailed information, check out our GitHub release page.
Rocket.Chat v7.0.0
Platform and database enhancements
We have upgraded the platform to Meteor 3.0 and Node.js 20, bringing in the latest security improvements, bug fixes, and performance optimizations. However, this update may require environmental adjustments, especially if your application relies on older Node.js features or Meteor packages. Developers should review their environment and ensure all dependencies are compatible with these new versions.
With MongoDB 4.4 reaching end-of-life, we have discontinued its support in favor of MongoDB 7.0. The new version offers enhanced performance, security improvements, and new features like support for multi-document ACID transactions. MongoDB 5.0 is now deprecated. If you're still using MongoDB 4.4 or 5.0, an upgrade is necessary to maintain compatibility with our platform. It’s important to test your database migration thoroughly to avoid potential data or performance issues.
Security and compliance updates
Removal of Compatible Sandbox (vm2) for Integration Scripts: We've fully removed the Compatible Sandbox option for integration scripts. Previously, Rocket.Chat allowed users to choose between two sandboxing libraries for script execution: vm2 (Compatible Sandbox) and isolated-vm (Secure Sandbox). Due to critical security vulnerabilities and lack of ongoing support for vm2, it is no longer available as of version 7.0. All scripts will now run exclusively in the Secure Sandbox environment. This change may impact integration scripts that relied on vm2's behavior. Review your integration scripts to ensure they are compatible with the secure sandbox.
Enhanced security for app installations: Starting with this release, the ability to upload private apps is now restricted to our Starter and Premium plans. This change helps us maintain the integrity of Rocket.Chat's customization options while safeguarding the exclusive features of our paid plans. By limiting private app uploads, we ensure that only licensed users can fully tailor their experience, protecting the value and security of our platform.
The ability to install apps from a URL will be removed.
Unused settings such as
UI_Click_Direct_Messageand theview-historypermission have been removed to comply with security best practices and reduce clutter.
Permissions and endpoint enhancements
New permissions for room management in teams: New permissions (
create-team-channelandcreate-team-group) have been added to enhance control over room creation within teams. These permissions integrate closely with team management functions and ensure proper visibility and control.Improved error messaging for login attempts: The login process will no longer suggest which credential is incorrect, returning a generic "Unauthorized" error instead to enhance security.
Disabled query and fields API parameters: The
queryandfieldsparameters have been disabled and can only be enabled by setting theALLOW_UNSAFE_QUERY_AND_FIELDS_API_PARAMS: trueenvironment variable. Enabling them may expose your workspace to security breaches, for which Rocket.Chat is not responsible. These parameters will be completely removed on 9.0.0.
Omnichannel and integration adjustments
Fixes for stuck omnichannel rooms: A migration will correct the statuses of inquiries linked to rooms that are closed but still listed as active due to systemic issues.
Removed dependencies: The dependency on the
meteor/checkpackage has been removed from all v1 endpoints to avoid errors and enhance performance.
Air-gapped workspace restrictions for commercial licensing
Starting with this release, Rocket.Chat Community Edition will no longer support air-gapped environments (environments without internet access). To ensure compliance with licensing agreements, only users on premium plans—including the free Starter plan—can run Rocket.Chat in these air-gapped setups. Our standard builds include commercial code, so restricting air-gapped environments to premium users helps maintain security and proper licensing compliance. Community users who need Rocket.Chat without commercial restrictions can use the fossify script. This tool removes all premium code, leaving a fully open-source version with no limitations (e.g., no user or MAC limits). While this doesn’t include our commercial air-gapped setup, it allows users to build their own offline solutions and customize them on top of our open-source code as they wish. For details, check out the fossify script.
Several outdated features have been removed to streamline the codebase and improve overall system performance:
HipChat importer removed: Due to the discontinuation of HipChat, the HipChat importer is no longer supported. If you’re still migrating from HipChat, consider using alternative import methods or manually migrating your data.
Unused oauth settings removed: We’ve pruned unused and outdated OAuth settings to simplify the configuration process. The button text color and button color settings will be removed. If your system still relies on these deprecated settings, update your configurations to avoid potential authentication issues.
API endpoint replacements and removals: The following older API methods and endpoints have been deprecated in favor of newer, more efficient ones.
Method | eraseRoom | Replaced by rooms.delete endpoint | 5.4.0 | 7.0.0 |
Method | roomNameExists | Replaced by rooms.nameExists endpoint | 5.1.0 | 7.0.0 |
Method | deleteMessage | Replaced by chat.delete endpoint | 6.2.0 | 7.0.0 |
Method | checkUsernameAvailability | Replaced by users.checkUsernameAvailability endpoint | 5.4.0 | 7.0.0 |
Method | listEmojiCustom | Replaced by emoji-custom.list endpoint | 5.4.3 | 7.0.0 |
Method | refreshClients | Now triggered by assets.setAsset and assets.unsetAsset | 5.4.0 | 7.0.0 |
Method | removeWebdavAccount | Replaced by webdav.removeWebdavAccount endpoint | 5.1.0 | 7.0.0 |
Method | Mailer:unsubscribe | Replaced by mailer.unsubscribe endpoint | 5.4.0 | 7.0.0 |
Method | Mailer.sendMail | Replaced by mailer endpoint | 5.4.0 | 7.0.0 |
Method | reportMessage | Replaced by chat.reportMessage endpoint | 6.2.0 | 7.0.0 |
Method | getPasswordPolicy | Replaced by pw.getPolicy endpoint | 5.1.0 | 7.0.0 |
Method | livechat:addAgent | Replaced by livechat/users/agent (POST) endpoint | 5.2.0 | 7.0.0 |
Method | livechat:addManager | Replaced by livechat/users/manager (POST) endpoint | 5.2.0 | 7.0.0 |
Method | livechat:getCustomFields | Replaced by livechat/custom-fields endpoint | 5.2.0 | 7.0.0 |
Method | livechat:getNextAgent | Replaced by livechat/agent.next/:token endpoint | 5.2.0 | 7.0.0 |
Method | livechat:loadHistory | Replaced by livechat/messages.history/:rid endpoint | 5.2.0 | 7.0.0 |
Method | livechat:loginByToken | Replaced by livechat/visitor/:token endpoint | 5.2.0 | 7.0.0 |
Method | livechat:pageVisited | Replaced by livechat/page.visited endpoint | 5.2.0 | 7.0.0 |
Method | livechat:registerGuest | Replaced by livechat/visitor endpoint | 5.2.0 | 7.0.0 |
Method | livechat:removeAgent | Replaced by livechat/users/agent/:_id endpoint | 5.2.0 | 7.0.0 |
Method | livechat:removeDepartment | Replaced by livechat/department/:_id endpoint | 5.2.0 | 7.0.0 |
Method | livechat:removeManager | Replaced by livechat/users/manager/:_id endpoint | 5.2.0 | 7.0.0 |
Method | livechat:saveDepartmentAgents | Replaced by livechat/department/:_id/agents endpoint | 5.2.0 | 7.0.0 |
Method | livechat:saveSurveyFeedback | Replaced by livechat/room.survey endpoint | 5.2.0 | 7.0.0 |
Method | livechat:searchAgent | Replaced by livechat/users/agent/:_id endpoint | 5.2.0 | 7.0.0 |
Method | livechat:sendOfflineMessage | Replaced by livechat/offline.message endpoint | 5.2.0 | 7.0.0 |
Method | livechat:setCustomField | Replaced by livechat/visitor endpoint | 5.2.0 | 7.0.0 |
Method | livechat:setDepartmentForVisitor | Replaced by livechat/visitor endpoint | 5.2.0 | 7.0.0 |
Method | livechat:discardTranscript | Replaced by livechat/transcript/:rid (DELETE) endpoint | 6.4.0 | 7.0.0 |
Method | livechat:getAgentOverviewData | Replaced by livechat/analytics/agent-overview endpoint | 6.4.0 | 7.0.0 |
Method | livechat:getAnalyticsOverviewData | Replaced by livechat/analytics/overview endpoint | 6.4.0 | 7.0.0 |
Method | livechat:removeTrigger | Replaced by livechat/triggers/:_id (DELETE) endpoint | 6.5.0 | 7.0.0 |
Method | livechat:requestTranscript | Replaced by livechat/transcript/:rid endpoint | 6.4.0 | 7.0.0 |
Method | livechat:saveAppearance | Replaced by livechat/appearance endpoint | 6.4.0 | 7.0.0 |
Method | livechat:saveInfo | Replaced by livechat/room.saveInfo endpoint | 5.3.0 | 7.0.0 |
Method | livechat:saveIntegration | Replaced by omnichannel/integrations (POST) endpoint | 6.2.0 | 7.0.0 |
Method | livechat:saveTrigger | Replaced by livechat/triggers endpoint | 6.4.0 | 7.0.0 |
Method | livechat:webhookTest | Replaced by livechat/webhook.test endpoint | 5.4.0 | 7.0.0 |
Method | livechat:getAgentData | Replaced by livechat/agent.info/:rid/:token endpoint | 6.4.0 | 7.0.0 |
Method | addOauthApp | Replaced by oauth-apps.create endpoint | 6.2.0 | 7.0.0 |
Endpoint | pw.getPolicyReset | Replaced by pw.getPolicy endpoint | 6.3.0 | 7.0.0 |
Endpoint | licenses.get | Replaced by licenses.info endpoint | 6.5.0 | 7.0.0 |
Endpoint | licenses.isEnterprise | Replaced by licenses.info endpoint | 6.5.0 | 7.0.0 |
Endpoint | channels.images | Replaced by rooms.images endpoint | 6.8.0 | 7.0.0 |
Endpoint | livechat/room.transfer | Replaced by licenses/room.forward endpoint | 5.2.0 | 7.0.0 |
Endpoint | livechat/inquiries.queued | Replaced by livechat/inquiries.queuedForUser endpoint | 5.4.1 | 7.0.0 |
Endpoint | livechat/room.visitor | The endpoint has been removed. | 5.2.0 | 7.0.0 |
The following parameters have been removed and replaced.
Method | authorization:removeUserFromRole | role | This parameter will no longer accept roleName as a fallback. Use only | 4.6.0 | 7.0.0 |
Method | authorization:deleteRole | role | This parameter will no longer accept roleName as a fallback. Use only | 4.6.0 | 7.0.0 |
Method | authorization:addUserToRole | role | This parameter will no longer accept roleName as a fallback. Use only | 4.6.0 | 7.0.0 |
Method | apps (POST) | downloadOnly | This parameter will no longer be accepted. | 6.6.0 | 7.0.0 |
This update is critical for maintaining the operational integrity, security, and efficiency of Rocket.Chat workspaces. Workspace managers should review these changes carefully and begin preparations for a smooth transition to version 7.0.0.
