Webhooks
Prev Next
The Omnichannel Webhooks feature allows you to integrate Omnichannel with any third-party system, e.g., CRM, Zoho, etc.
Create Omnichannel webhook
To create a new Omnichannel webhook, go to Administration > Omnichannel > Webhooks.
  • Webhook URL: Enter the destination webhook URL where the data will be sent.
  • Secret Token: Enter a secret token that can be used to verify the webhook.
The field Secret Token is sent to a header X-RocketChat-Livechat-Token so that you can validate if the request is from Livechat. If your endpoint returns a response status other than 200, Rocket.Chat will retry ten times, waiting ten seconds between retries.
  • Send Request on: Select the actions or events that will trigger this integration and send data to the webhook, such as when a chat is taken or when a visitor sends a message. The available options are:
    • Chat Start
    • Chat Close
    • Chat Taken
    • Chat Queued
    • Forwarding
    • Offline Messages
    • Visitor Messages
    • Agent Messages
  • HTTP timeout (in milliseconds): Enter the request timeout value.
  • Click Save.
  • Click Send Test to verify the webhook setup. If successful, a message saying It works will be displayed. You will receive a sample JSON response at the configured URL.
  • You can also Reset the values for the Webhook setup.
The Webhook URL and Secret Token configured here are automatically populated in the Webhooks settings under Administration > Workspace > Settings > Omnichannel > CRM Integration.
Sample JSON data
Below is an example of the JSON data received by the webhook URL:
  "_id": "Tc5SyBZHovD4k8BXv",
  "label": "James",
  "createdAt": "2023-02-02T10:16:07.230Z",
  "lastMessageAt": "2023-02-02T10:22:14.087Z",
  "tags": [
    "self"
  "visitor": {
    "_id": "63db8d4990fe6eda42ad429a",
    "token": "e36e352c742eee48860d576fcefb372afc44ebc95750fa1e3b646195f702341a",
    "name": "James",
    "username": "guest-3",
    "email": [
        "address": "abc.xyz+local-on@rocket.chat"
    "phone": null
  "agent": {
    "_id": "aXjjcPwq4Pcp7xftH",
    "username": "user1",
    "name": "User One",
    "email": "uaser1@mail.com"
  "type": "LivechatSession",
  "messages": [
      "u": {
        "name": "James"
      "_id": "2untSdndqBP7opGWw",
      "msg": "Hi",
      "ts": "2023-02-02T10:16:09.615Z"
      "u": {
        "name": "User One"
      "_id": "7xjkw8ZFitMSNGmeJ",
      "msg": "How can I help you today?",
      "ts": "2023-02-02T10:21:05.391Z",
      "agentId": "aXjjcPwq4Pcp7xftH"
      "u": {
        "name": "James"
      "_id": "y7p77YFfkHJeg5gD9",
      "msg": "don't worry,thank you",
      "ts": "2023-02-02T10:22:14.087Z"
      "u": {
        "name": "User One"
      "_id": "ciAggDuN8ioqDrTby",
      "msg": "Thank you for visiting",
      "ts": "2023-02-02T10:23:11.437Z",
      "agentId": "aXjjcPwq4Pcp7xftH",
      "closingMessage": true
  "servedBy": {
    "ts": "2023-02-02T10:16:07.375Z"
  "closedAt": "2023-02-02T10:23:11.344Z",
  "closedBy": {
    "username": "user1"
  "closer": "user"
  "label": "James",
  "lastMessageAt": "2023-02-02T10:16:09.615Z",
  "visitor": {
    "name": "James",
    "email": [
    "phone": null
  "agent": {
    "name": "User One",
  "type": "Message",
  "messages": [
      "u": {
        "name": "User One"
