LDAP Premium Settings
Prev Next
From Rocket.Chat 9.0.0, LDAP is available on Starter workspaces and on all premium plans (Commercial, Government, and Defense). It is not available on Community workspaces. See Our Plans for details.
LDAP Premium Settings provide advanced controls for user synchronization, account lifecycle management, and attribute handling within your LDAP integration.
Background Sync
Configure automated synchronization between Rocket.Chat and your LDAP directory.
Setting Name
Background Sync
Enables or disables automatic background synchronization between Rocket.Chat and the LDAP directory.
Background Sync Interval
Defines how often synchronization runs using Cron Text format (for example: 0 */6 * * * for every six hours, 0 0 * * * for once every 24 hours).
Background Sync Import New Users
Imports users that exist in LDAP but not in Rocket.Chat, based on your configured LDAP filters.
Background Sync Update Existing Users
Updates attributes (such as avatar, fields, or username) for users already imported from LDAP.
Background Sync Merge Existing Users
Merges accounts that exist in both LDAP and Rocket.Chat. Requires the Merge Existing Users option in the Data Sync tab to be enabled.
Automatically Disable Users Not Found in LDAP
Deactivates Rocket.Chat users whose LDAP entry no longer exists. Disabled users appear under Administration → Workspace → Users with the status Disabled. Room ownership is reassigned or removed when applicable.
Avatar Background Sync
Enables a separate synchronization process for updating user avatars.
Avatar Background Sync Interval
Defines how often avatar synchronization runs using Cron format.
“Automatically Disable Users Not Found in LDAP” can delete rooms. If a disabled user was the only owner and only member of a private room, that room and every discussion inside it are deleted with no prompt. See the note under Sync User Active State section for details.
Sync ABAC Attributes
The Sync ABAC Attributes settings control how Rocket.Chat synchronizes LDAP user attributes used for Attribute-Based Access Control (ABAC).
These settings are available on Starter workspaces and Defense plan.
Setting
ABAC Attributes Background Sync
Enables a separate background process to synchronize user ABAC attributes from LDAP. When enabled, Rocket.Chat periodically updates mapped ABAC attributes for users.
ABAC Attributes Background Sync Interval
Defines how often ABAC attribute synchronization runs. Uses Cron Text format (for example: 0 0 * * *).
ABAC Attribute Mapping
Defines how LDAP user attributes map to Rocket.Chat ABAC attributes. The value must be a JSON object where: • Each key is an LDAP attribute name. • Each value is the ABAC attribute name stored in Rocket.Chat.
ABAC attribute mapping format
The mapping must be a JSON object.
Example:
  "department": "dept",
  "region": "region"
See the Configure ABAC user guide for more information.
Sync Teams
The Sync Teams settings allow you to map and synchronize LDAP teams with Rocket.Chat teams.
Setting
Enable team mapping from LDAP to Rocket.Chat
Enables team mapping between LDAP and Rocket.Chat. When enabled, team assignments are synchronized based on the configured mapping and LDAP query.
Team mapping from LDAP to Rocket.Chat
Defines the mapping between LDAP teams and Rocket.Chat teams. The value must be a JSON object that maps LDAP identifiers to Rocket.Chat team names.
Validate mapping for each login
Determines whether users' teams are updated every time they log in. If disabled, team assignments are loaded only during the user’s first login.
LDAP Teams BaseDN
Specifies the LDAP BaseDN used to look up user teams.
LDAP Team Name Attribute
Specifies the LDAP attribute Rocket.Chat should use to load the team's name. Multiple attributes can be provided by separating them with commas (for example: ou,cn).
LDAP query to get user groups
Defines the LDAP query used to identify which groups a user belongs to (for example: (&(ou=*)(uniqueMember=#{userdn}))).
Team mapping from LDAP to Rocket.Chat format
The Team mapping from LDAP to Rocket.Chat field must contain a JSON object.
Example:
  "ldap-team-1": "RocketChatTeamA",
  "ldap-team-2": "RocketChatTeamB"
  • Each key represents an LDAP team identifier.
  • Each value represents the corresponding Rocket.Chat team name.
Only mappings defined in this object are synchronized.
Auto Logout Deactivated Users
Configure automatic logout for users who have been deactivated.
Setting
Enable Auto Logout
When enabled, Rocket.Chat automatically logs out users who have been deactivated.
Auto Logout Interval
Defines how often Rocket.Chat checks for deactivated users and logs them out. The interval uses the Cron Text format.
Auto Logout interval format
The Auto Logout Interval field uses standard cron syntax.
Example:
*/5 * * * *
This configuration logs out deactivated users every five minutes.
You can adjust the schedule based on your operational or security requirements.
Sync Custom Fields
Configure Rocket.Chat to synchronize custom fields from your LDAP directory.
Setting
Sync Custom Fields
Enables synchronization of custom fields from LDAP to Rocket.Chat. When enabled, Rocket.Chat will process the configured mapping and update user custom fields accordingly.
Custom Fields Mapping
Defines how LDAP attributes map to Rocket.Chat custom fields. The value must be a JSON object that specifies the relationship between LDAP attributes and Rocket.Chat custom field names.
Custom Fields mapping format
The Custom Fields Mapping field must contain a JSON object.
Example:
  "departmentNumber": "department",
  "employeeType": "roleType",
  "extensionAttribute1": "region"
  • Each key represents an LDAP attribute.
  • Each value represents the corresponding Rocket.Chat custom field name.
Only the attributes defined in this JSON object are considered in the mapping.
Advanced Sync
Configure advanced LDAP synchronization settings to manage user states and query attributes.
Controls whether Rocket.Chat activates or deactivates users based on their account status in LDAP. It applies only to users that Rocket.Chat finds in LDAP. Rocket.Chat treats a user as disabled when the LDAP account is disabled. The default is Disable users.
Option
Do nothing
Rocket.Chat doesn't change the user's active state.
Disable Users
Deactivates users whose LDAP account is disabled. It never reactivates users.
Enable Users
Reactivates users whose LDAP account is enabled. It never deactivates users.
Enable and Disable Users
Keeps the user's active state the same as in LDAP.
This setting is separate from Automatically disable users that are no longer found on LDAP, which deactivates users that the sync can't find, for example after they're removed from your search filter. With the default Disable users, those users stay deactivated even after they're added back. To reactivate them automatically, choose Enable users or Enable and disable users.
Deactivating a user can change room ownership or delete rooms. This applies whether the user is deactivated by this setting or by Automatically disable users that are no longer found on LDAP.
  • If the user was the last owner of a room with other members, the member who joined earliest becomes the new owner.
  • If the user was the only owner and the only member of a private room, the room and all its discussions are deleted. There's no confirmation prompt and no setting to prevent this.
With Enable users or Enable and disable users, users you deactivated manually in Rocket.Chat are reactivated if their LDAP account is still enabled.
To decide whether an LDAP account is disabled, Rocket.Chat checks the following provider-specific attributes. What happens next depends on the selected Sync User Active State option.
  • eDirectory: Uses loginDisabled to check whether the account was manually disabled by an administrator.
  • Oracle Directory: Uses orclIsEnabled. If the account status is not ENABLED, the user is treated as disabled.
  • Active Directory: Uses userAccountControl. The account is treated as disabled when the ACCOUNTDISABLE flag (value 2) is set.
To verify user status, navigate to: Manage → Workspace → Users
If you customize Attributes to Query, include the relevant provider-specific attribute used for active-state sync, such as loginDisabled, orclIsEnabled, or userAccountControl.
Attributes to Query
Defines which attributes should be returned in LDAP queries. Separate multiple attributes with commas.
  • * = All regular attributes
  • + = All operational attributes
Make sure to include every attribute required for Rocket.Chat sync options.
Sync Channels
Configure how your LDAP groups map to Rocket.Chat channels.
Setting
Auto Sync LDAP Groups to Channels
Automatically add users to channels based on their LDAP group. If you also want to remove users from a channel, see the option Auto Remove Users from Channels.
Channel Admin
When channels are auto-created that do not exist during a sync, this user automatically becomes the admin for the channel.
LDAP Group BaseDN
The BaseDN used for group lookups.
Group membership validation strategy
Determines how users' memberships to LDAP groups are validated.
User Group Filter
The LDAP search filter used to check if a user is in a group.
LDAP Group Channel Map
Map LDAP groups to Rocket.Chat channels using JSON format.
Remove users from channels if they are no longer in the corresponding LDAP group.
Apply filter for each group
  • Applies the LDAP user group filter for each group (key) defined in the LDAP Group Channel Map.
  • Slower, since it performs a separate check per group.
  • Useful when using the #{groupName} replacement tag in the User Group Filter.
Apply filter once to get all memberships
  • Applies the LDAP user group filter once per user.
  • A user is considered a member of all groups returned by the LDAP search.
  • Faster option.
  • Do not use the #{groupName} replacement tag with this strategy.
Switching to Apply filter once to get all memberships may not work with your current LDAP search filter. If you use this option, update the User Group Filter so it retrieves all groups in a single query.
User Group Filter
The LDAP search filter used to check if a user is part of a group.
Supported placeholders
  • #{username} → The user’s Rocket.Chat username
  • #{groupName} → The group’s name in LDAP
  • #{userdn} → The user’s LDAP DN
Example:
(&(cn=#{groupName})(memberUid=#{username}))
Example:
  "employee": "general",
  "techsupport": [
    "helpdesk",
    "support"
  • "employee": "general" → Adds users in the LDAP group employee to the general channel.
  • A group can map to a single channel or to multiple channels using an array.
When enabled, users are removed from channels if they are no longer members of the corresponding LDAP group.
Sync Roles
You can sync user roles from your LDAP groups to your Rocket.Chat workspace.
Setting
Sync LDAP Groups
Enable this setting to activate role mapping from LDAP groups.
Auto Remove User Roles
Automatically remove roles from users if they are not assigned in LDAP. This only removes roles that are defined in the User Data Group Map.
LDAP Group BaseDN
The LDAP BaseDN used to look up users.
User Group Filter
User Data Group Map
Map LDAP groups to Rocket.Chat user roles using JSON format.
  • Applies the User Group Filter for each group (key) defined in the User Data Group Map.
  • Applies the User Group Filter once per user.
  • Faster option.
Switching to Apply filter once to get all memberships may not work with the currently configured LDAP search filter. If you use this option, update the User Group Filter to retrieve all groups in a single query. Do not use the #{groupName} replacement tag with this strategy.
User Group Filter
Defines the LDAP search filter used to check if a user belongs to a group.
If the search returns results, the user is considered a group member.
  • #{username} → Replaced with the Rocket.Chat username
  • #{groupName} → Replaced with the LDAP group name
  • #{userdn} → Replaced with the LDAP Distinguished Name (DN) of the user
Example:
User Data Group Map
Maps LDAP groups to Rocket.Chat roles in JSON format.
Example:
  "rocket-admin": "admin",
  "tech-support": "support",
  "manager": ["leader", "moderator"]
In this example:
  • The rocket-admin LDAP group maps to the admin role.
  • The tech-support LDAP group maps to the support role.
  • The manager LDAP group maps to the leader and moderator roles.
