Run a Botkit Bot
Botkit is the leading developer tool for building chat bots, apps and custom integrations for major messaging platforms.
Botkit offers everything you need to design, build and operate an app:
In addition, Botkit works with all the NLP services (like Microsoft LUIS and IBM Watson), it can use any type of database, and runs on almost any hosting platform.
Quick start guide
Botkit is a Node.js module and works with Node and npm.
The fastest way to start with Botkit is using botkit-starter-rocketchat:
1. clone the starter repo and install dependencies
git clone https://github.com/RocketChat/botkit-starter-rocketchat
cd botkit-starter-rocketchat/
npm install
2. create a .env file with the following content
ROCKETCHAT_URL=<ROCKETCHAT HOST>
ROCKETCHAT_USER=<BOTKIT USER NAME>
ROCKETCHAT_PASSWORD=<BOTKIT USER PASS>
ROCKETCHAT_USE_SSL=<SSL USAGE>
ROCKETCHAT_ROOM=<ROCKETCHAT CHANNEL>
MENTION_ROOMS=<CHANNEL THAT THE BOT WILL ONLY ANSWER WHEN MENTIONED>
RESPOND_TO_DM=<ENABLE BOT TO RESPOND TO DIRECT MESSAGES>
RESPOND_TO_LIVECHAT=<ENABLE BOT TO RESPOND TO LIVE CHAT>
RESPOND_TO_EDITED=<ENABLE BOT TO RESPOND TO EDITED MESSAGES>
3. run the bot
npm start
After executing the command, botkit will try to connect to the Rocket.Chat instance and then will listen to messages in general room:
Initializing Botkit v0.6.16
info: ** No persistent storage method specified! Data may be lost when process shuts down.
debug: Setting up a handler for spawned
debug: Setting up a handler for heard_trigger
debug: Setting up a handler for command_triggered
debug: Setting up a handler for remote_command_end
debug: Setting up a handler for direct_message
debug: Setting up a handler for live_chat
debug: Setting up a handler for channel
debug: Setting up a handler for private_channel
[connect] Connecting { username: 'mybotuser',
password: 'mypassword',
ldap: false,
host: 'myserver.com',
useSsl: true,
timeout: 20000,
rooms: [ 'GENERAL' ],
allPublic: false,
dm: true,
livechat: true,
edited: true,
integrationId: 'js.SDK',
roomCacheMaxSize: 10,
roomCacheMaxAge: 300000,
dmCacheMaxSize: 10,
dmCacheMaxAge: 100000 }
debug: Setting up a handler for message_received
debug: Setting up a handler for sticker_received
debug: Setting up a handler for image_received
debug: Setting up a handler for audio_received
debug: Setting up a handler for conversationStarted
NOTE: Botkit Studio functionality has not been enabled
To enable, pass in a studio_token parameter with a token from https://studio.botkit.ai/
Botkit Studio statistics are no longer supported. Update your project to the latest version of Botkit, or add `stats_optout: true` to your bot configuration.
[connect] Connected
[login] Logging in mybotuser
[getRoomIdByNameOrId] Calling (caching): GENERAL
[getRoomIdByNameOrId] Success: "GENERAL"
[joinRoom] Calling (async): ["GENERAL"]
[joinRoom] Success
[subscribe] Preparing subscription: stream-room-messages: __my_messages__
[subscribe] Stream ready: 4
[reactive] Listening for change events in collection stream-room-messages
4. talk to your bot
On the server, login as a regular user (not the BOT user), go to general room, and try to talk to your bot:
Botkit bot is talking
Edit on GitHub
